Quick Start Guide
This is a quick start guide summarising the steps to download, install and configure SnakeoilOS. Gear Isolation is now simpler than ever.
  1. Install Ubuntu Server.
  2. Login to your newly installed machine.
  3. Install curl
    apt install curl
  4. Download Snakeoil public key
    curl -sSSL https://artifacts.snakeoil-os.net/apt-repo/snakeoilos-main.pgp | \
            sudo tee /usr/share/keyrings/snakeoilos-main.pgp >/dev/null
  5. Add Snakeoil repo to your newly installed machine
    echo 'deb [signed-by=/usr/share/keyrings/snakeoilos-main.pgp] \
        https://artifacts.snakeoil-os.net/apt-repo noble main' | \
        sudo tee /etc/apt/sources.list.d/snakoeil-os.list
  6. Run apt update
    sudo apt update
  7. Install Snakeoil package and all associated dependencies
    sudo apt install snakeoil
  8. Reboot
    sudo reboot
Reference Chapter
